6 Deg. Angle On Dist. For LT1 Intake
Old May 2, 2002 | 09:54 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Which way does the distributor tilt for the 6*? I'm going to make a spacer in shop class so i figured i'd ask which way it tilts so i know when i get ready to put all my stuff together for the LT1 intake swap. I did do a search but people just talked about it. So i'm kinda clueless on the 6* tilt, or if i even need it. Thanks.
Old May 2, 2002 | 12:44 PM
rhuarc30's Avatar
towards the driver sided I think.
Old May 2, 2002 | 06:25 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Alrighty, thats all i needed to know.
Old May 2, 2002 | 07:21 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, towards the driver side.
Old May 2, 2002 | 07:51 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Thanks John, a picture is worth a 1,000 words at lease for me. Btw, for the fuel lines do i need to send my current ones or the ones on your website for new ones?
Old May 2, 2002 | 09:26 PM
Engine: 4.0L
I'm a little confused about your question. You want to know if you can use your stock fuel lines or my custom lines? With a LT1 intake you will need custom lines as the fuel rail has a quick disconnect fitting unlike the TPI.
Old May 3, 2002 | 10:51 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
That part i understand, but i didn't understand if i send my current fuel lines off to you to get redone for the manifold, or if you only offer the lines all new.
Old May 3, 2002 | 11:19 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
You dont actually send your LT1 aluminum lines off to John to be redone or modified. For $80-85 (He has two different prices on his site for some reason) he will send you new rubber lines that replace your TPI's rubber lines. These lines go from your Lt1 aluminum line's fitting to the tubing that sits on the frame rail. Hope that answered your question. See ya
Old May 3, 2002 | 02:43 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Yep, thanks, now to get the intake finished and find some fuel rails.
Old May 7, 2002 | 09:29 PM
FstBrd6point3's Avatar
how come the distributor needs to be tilted, it isn't on my 87 TPI. . . or is it?
Old May 7, 2002 | 09:35 PM
Engine: 4.0L
It is, look closer.
Old May 7, 2002 | 11:13 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Hard to see with engine in car. If you remove the intake, you'll see the the casting where the Dist. seets is higher on the passenger side. The intake does not set this angle. The bore in the block sets it. The purpose is for the Dist gear and camshaft gear to mess properly.
92projectcamaro
Jan 18, 2016 08:00 AM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
