Dead Injectors?
Old May 2, 2002 | 03:56 PM
robert1's Avatar
Dead Injectors?
I just put in a set of used, flow matched injectors. I noticed #1 and #3 cylinders aren't running but they have spark. This means the injectors aren't flowing gas? Any ideas people?
Old May 2, 2002 | 07:14 PM
Bort62's Avatar
pull the plugs on the suspect cylinders, are they wet ?
Smell like gas ?
Whats the story on the injectors ?
if the plugs are coming out dry, verify that the wires going to the suspect injectors are intact, and your getting a pulse like you should.
Old May 3, 2002 | 05:54 PM
robert1's Avatar
Yes, the plugs were firing, but dry. The wires looked ok, but I'll test them with a light. The injectors were from S&P, a used, but good matched set.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
