porting and polishing the plenum and runners
Old May 3, 2002 | 12:22 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i know how to polish the plenum, but i'm not sure on how to do the runners. is it the same process or do you do something different? can you even polish the stock runners? and also, is it pointless to port the plenum and stock runners? thanks
Old May 3, 2002 | 12:26 PM
sIcK pUpPy's Avatar
Without sounding like an ***, did you do a search of the board on this topic? It has been covered extensively. If you cannot find what you need after that, we'll do our best to help.
Lates,
JD
Old May 3, 2002 | 12:27 PM
87GTA57L's Avatar
go and do a 'search' on that and im sure you'll find more than enough info..
you beat me to it! heh..
Old May 3, 2002 | 02:44 PM
Jza's Avatar
Jza
It's not pointless if you've a cam or some other mild mods. On a stock motor, it probably helps a bit, but it'll mostly just move the powerband up more than add to the overall power. And free up some high-RPM, say over 4700.
As far as polishing the runners, yeah, it's the same process for polishing anything made of aluminum. Typically, polishing machined aluminum (like fuel rails) is much easier than cast aluminum (pretty much everything else on the TPI). The only thing is that those runners are so odd shaped and hard to work with, it's a pain in the *** to polish.
Here's a pic of my runners before and after. I only mirror-polished the upper flange. Everything else I just hit with some steel-wool and Mother's Aluminum & Mag Polish. It's not as good as a full polish with sandpaper et al, but it sure was a lot easier. I also didn't want to do all that work if I was going to upgrade the runners soon anyway.
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Reid Fleming
Oct 10, 2015 09:56 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
