tpi airflow
Old May 10, 2002 | 11:38 AM
fourspeed's Avatar
tpi airflow
which is better for power/flow stock air cleaner setup (with gutted boxes) but gets cold air or a k&n on the throttle body (better air flow but hot air from engine bay)
Old May 10, 2002 | 11:45 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
good question. I have the cone filter, but have not run it any yet. I bought it used. I would like to see some comments on this a well.
Old May 10, 2002 | 11:53 AM
Guest
Guest
Posts: n/a
I'd say the cold air, though my 'proof' says otherwise.
I ran at the track through the somewhat stock setup on my 86 TA (3" ABS pipe in place of stupid square airbox) and it has a K+N filter... cant remember the ET or MPH but it was around a 15.5@88 or thereabouts. Next run I attached the MAF directly to the bellows and made another run. MUCH better throttle response. Maybe with some tuning, it would have run better but I do know the ET and MPH were so close it wasnt worth it. The radiator had the fans on, and it was running at 185 degrees. I dont think the hot air was causing any real problems.
chazman
Aug 28, 2018 03:25 PM
stalkier
Dec 6, 2015 11:25 PM
chazman
Aug 22, 2015 02:01 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
