what kind of 1/4 mile times can i be expecting?
Old May 12, 2002 | 02:00 AM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i know it's kind of hard to tell without ever seeing my car, but i'm just asking for estimates on what i can be running. right now i have a 92 305 5spd Z28 with the G92 option, i have the homemade ram air, airfoil, free flowing exhuast, forged pistons at a 10:1 compression ratio, mild cam, and my future mods are the slp 1 3/4 headers, big mouth manifold, ported plenum and runners(maybe the siamesed ones, but i'm not sure on which one is better), AFPR, and a 150 shot of NOS. what kind of times can i expect with this setup? i was thinking low 13's maybe hight 12's, does that sound reasonable? thanks
Old May 12, 2002 | 02:06 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your compression ratio is a little high for nitrous, but you should be faster than I am right now.
I dont know how experienced you are with nitrous, but start small with a 50 shot, and work your way up to a 150 shot as you get used to it and how the car reacts. And start saving for a T56 or other aftermarket tranny, because you'll break the T5 like I did.
Old May 14, 2002 | 06:30 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
man last time I was here kevin you were all proud that your t5 as holding up
Old May 14, 2002 | 09:09 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Wait, does nitrous not like higher compression??? I thought it was tolerated very well unlike boost and high compression. That is why the ls1 cars run very well with n20. Is this correct?
Old May 15, 2002 | 12:00 AM
Kevin91Z's Avatar
Yah, well that was when I was only getting 2.0 and 2.1 60's... I improved a tenth there and I still suck, but the T5 sucked more.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
ezobens
Aug 19, 2015 10:29 PM
kyle5647
Aug 7, 2015 03:08 PM
