Polished and Ported , now what ?
Hey people , I got a hold of a TPI ... the intake as been ported all around , same for the runner and the plenum . the trottle body is still stock ... I'm currently building a 72 350 SBC 4 bolt.
How much HP - TORQUE can this TPI setup supply to my motor ? Assuming everything is working well without problems.
Can someone also tell me if it's worth it to get a stock Trottle Body modded by SLP that flows 900 cfm for 95 $ ????
Its impossible to guess your hp/torque without every part of your combination listed
but you'll never see a terrible amount with stock tpi parts, even ported. You can go a step further and siamese it, but untill you get into aftermarket products the stock TPI base will just never flow enough.
This is evidient first time you put a felpro 1205 gasket under a tpi base.
I'd say you might run around 320-350hp assuming the rest of the combo is up to par
bigjay89gta
Oct 15, 2015 08:04 AM
