Please Someone??????
Old May 16, 2002 | 12:43 PM
SMOKEN's Avatar
OK GUYS I got a 1986 305 tpi trans am with ws6 i got the 350 exhaust i no i got this because my friends 89 iroc 350 has exactly the same ok now i need to no does this mean my ta has the 350 cam also i realy need to no because i plan on changing the cam and i want some good advice on the cam to choose thanksguys
k@n filter
hypertech chip
airfoil
no cat
free flowing muffler
8mm wires
Old May 16, 2002 | 02:58 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
I would say no you have a 305 cam just with a little better lift than most but if I was you are gonna get a cam either get summits tpi cam for your car or get the compu cam by comp cams both are available thru your summit catalog online.
Old May 16, 2002 | 03:01 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm not sure I can quite figure out what the hell you're asking, but I'll try to answer my interpretation.
All 86 TPI cars came with the peanut cam.
I believe that the 86 TPI cars had the same exhaust manifolds, y-pipe & cat as the single-cat L98 cars. The L98 may have had a slightly larger diameter intermediate pipe, I can't recall. Unless your 86 is a low milage car, it's quite doubtful that it still has the factory exhaust anyway, so it's tough to make any comparisons.
Old May 17, 2002 | 12:09 PM
SMOKEN's Avatar
the car has 20 000 miles on it even original rubber the reason that i'm asking is because i seen some other tpi 305 's exhaust and they were the same as the tbi ones all i can tell you is my car runs the q -mile at 15.7 with the 2.77 gears all i changed was the wires plugs airfoil k@n muffler removed the cat and hypertech chip
so this time sucks
