Help Plz!!!
Old May 21, 2002 | 05:46 PM
86IrocMN's Avatar
Help Plz!!!
This is really stupid but...I polished my runners and plenum and Im not quite sure which bolts go where...I know i shoulda marked em but does anyone know where there is a diagram showing this?
Old May 21, 2002 | 07:09 PM
Wolfpack's Avatar
Car: 86 Iroc
Shop Manual should help...good luck
Old May 22, 2002 | 01:39 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Shop manual only shows the bolt that holds the throttle cables.
You almost can't screw it up. each side is a mirror image. 2 bolts of this length go in the same holes on both sides.
If it's too short then obviously it doesn't go there. Try them out. See what fits where.
I believe the torque is only 25 lb-ft. So don't try forcing anything.
sorry i couldn't be more help. i had the same problem and doing what i said above gave me no problems.
Old May 23, 2002 | 12:50 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Short screw to plenum. Long screws to intake. Medium screws (2) underneath plenum into runners.
inferno15
Aug 29, 2015 01:48 AM
BitchinCamaro
Nov 28, 2001 01:51 PM
Amrish
Nov 9, 2001 11:33 AM
Amrish
Jul 16, 2001 02:16 PM
