What do ya think?
Old Jul 5, 2002 | 03:05 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
What do ya think?
O.K you guys tell me what ya think about this set up..
I have a 91 350 TPI, I am keeping the stock plenum and just porting and cleaning it up real good, I have Slp runners and Accel intake, I ordered a set of AFR 190 heads milled to 64 and they have the spring upgrade, Msd digital 6 and msd coil, NX wet kit (35-150) I think I am going with the LPE211 cam .211/219 .530/.560 *112 with 1.6 rr's, she will be getting new rods and pistons and I will get the crank checked out
How do you think she will run??Am I missing anything?
Old Jul 5, 2002 | 06:09 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
A good timing chain or gear drive.
New lifters and pushrods obviously.
Injectors?
Old Jul 5, 2002 | 10:50 PM
89Irocz23's Avatar
Im thinking at least mid to low 13s. Have you dont any suspention work yet? If not I would cause your gonna need some traction. Maybe you could be in the 12s if you can hook. Also your gonna need some prom burning as well.
Old Jul 6, 2002 | 12:44 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Yes I will get a good timing chain and get some new lifters, also I was thinking SVO 24lbs injectors.
All my susp. mods are in the sig.
I also have some SLP headers and the rest of the exhaust will be replaced, Dont know if I will keep the cats or not yet.
Thanks for the info though
Old Jul 8, 2002 | 02:43 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
double post..
Old Jul 9, 2002 | 05:14 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Come on now I know someone out there can share a little knowledge on this.....
Old Jul 9, 2002 | 07:34 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
You will probably run clso to what this guy does, or maybe a little faster.
Gofasterfirebird:
1991 Firebird
Stock 350 L98 shortblock (was a 305 TBI)
AFR street 190s 64cc 9 to 1
Accel Base Manifold
Stock Runners
Stock Plenum
aftermarket T-56
SLP cam (206 212 .480 .486)
AFR 190s
3.23s
12.33 @ 114.83 juiced (150 shot) uncorrected
13.510 @ 102 non juiced uncorrected
