fuel injectors
Old Jul 7, 2002 | 12:28 PM
pokes87iroc's Avatar
fuel injectors
will mustang injectors work in a tpi setup and what r the flow rates on the two thanks
Old Jul 7, 2002 | 03:59 PM
TPI K5's Avatar
Mustang injectors are 19 lb/hr. I have them on my setup, I think they might be too short but I'm not sure yet (the swap isnt finished yet). I will let you know if they work
Old Jul 7, 2002 | 07:27 PM
in summit they have the same part number for the injectors with the same lb/hr
Old Jul 7, 2002 | 09:01 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
injectors
from what i know they have a better spray nozzle better spray pattern at a lower psi
Old Jul 7, 2002 | 09:02 PM
91zeder's Avatar
I had 19lbs svo injectors put in my LB9 2 months ago. They work great.
Old Jul 7, 2002 | 09:11 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
They fit perfect, and work perfect. But beware, theyre rated at a lower PSI than GM, so adjust your fuel pressure accordingly. Your stock FP should acually work well with them, theyll give you a little more fuel and better atomization.
Old Jul 8, 2002 | 06:27 AM
what do i want to get them out of what year stang
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
