Switching to LT1 intake from carb
Old Jul 11, 2002 | 12:17 PM
Blackened's Avatar
I just need some opinions from people who've done this before or longer then I have
Would a 58mm TB and #30lb injectors pretty much be required for running it on a 412 ? Should I go with a smaller cam ?
I'm switching back to FI because carbs just suck. I'm tired of always fixing it and tuning it to get it just right. At least with TPI (FI) I can go back to just taking the chip inside with me and comfortable sitting in my chair editing numbers and looking at graphs :P
Old Jul 12, 2002 | 01:21 AM
89Irocz23's Avatar
Go to www.lt1intake.com and e-mail john he has the most experience with the lt1 intakes.
Old Jul 12, 2002 | 03:13 AM
Blackened's Avatar
Yeah I already did I'm going to get one from him. I'm sure he wont know what my combo will require, that's why I'm trying to get some opinions here from people that use minirams or stealthrams.
Old Jul 12, 2002 | 10:29 PM
rhuarc30's Avatar
Well is the cam a roller, hydraulic roller, flat tappet what? If it's a solid roller, it'll be fine, hyrdraulic flat tappet or roller it may be a bit big for a street car. Solid flat tappet will be on the rowdy side for street car but probably doable. 30# injectors should theoretically be good up to a bit over 500 hp at stock fuel pressure, get an AFPR and you can go a bit higher. As far as the TB depends on what kind of power and rpm you want to turn. But having said that the price difference between a 52 and 58 is only like 10-20 bucks from summit, so I'd go with the 58.
Old Jul 13, 2002 | 12:17 AM
titeride85's Avatar
blackened, whatever you find out let me know. I am considering it too. I'm not sure though. Do you have to have the A.I.R. system and smog equipment if you go to FI? I might be better off for right now going with the carb.
Old Jul 13, 2002 | 06:42 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Nope. I removed mine a long time ago...
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
