TPI tuning questions!
Old Aug 5, 2002 | 09:33 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Well, new motor is in. Mods in sig. I have a Monitor 4000E scanner I've been using to watch the new motor. A few questions:
1)Should my IAC counts rise as I rev the motor?
2)Should my SAP (spark advance) be up to almost 50*?
3)At same time as above, should my knock retard be 20* or so?
4)I'm NOT receiving any knock so I'm not sure about the knock retard. Is that how its supposed to work?
5)Also, what should Inj PW be at? Any normal number they should be around? SHould they rise as I rev it?
*I'm new to the tuning stuff, and I'm gonna have to learn somehow I guess. Thanks for ANY info. Later
Old Aug 5, 2002 | 03:29 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
re:
BTW- those 50* advance numbers were when I was driving it at somewhat normal throttle going thru the gears. (2-3 grand)
23 views and no replies? Anyone???????
TTT
Old Aug 5, 2002 | 04:34 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Hey. I have a couple Excel files I got after running around with Moates' ECM software that I can mail to you if you want. Give you an idea what another one looks like. Though I only have a stock run and one of the mods listed below.
David
PS i still have the stock chip with no reprogramming.
Old Aug 5, 2002 | 04:42 PM
kevosiroc's Avatar
1. yes, IAC count should rise as throttle position increases
2.??? maybe software interface problem???
3. knock retard should be at Zero. Check wiring and connection. 4. Does not have to show knock to retard.
5. mine is at 1.8-2.8 with fuel pressure at 55 psi. It can change a lot with engine speed.
Old Aug 5, 2002 | 06:15 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
re:
Thank soooooooooo much guys. I was getting a code 43 ESC failure. I replaced my knock sensor with my 305 one and the code is gone.(305 KS had ~3000 ohms.... 350 KS had 0 ohms = JUNK) I'm watching it with the scanner too. Still no knock present! As for that 8 or so degrees knock retard at idle and 20* when driving, I guess that was a safety put out by the ECM b/c there wasn't any communication with the knock sensor. It should be running alot better now. Guess that KS was all my problems. Thanks for all the info guys! Later
Old Aug 5, 2002 | 06:25 PM
91cop's Avatar
Car: denali truck,91b4c,82pacecar
Engine: 6.0,5.7.5.0
Transmission: auto
Axle/Gears: 4.10,3.55,3.23
Where did you get the monitor 4000e scanner?
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
