Comp 280HR too much?
Old Aug 16, 2002 | 12:38 PM
Forgiven's Avatar
I've got a shot at a used retrofit hydraulic roller comp cams 280HR camshaft:
280/280 adv
224/224 (.050)
525/525 lift
LC 110
2000 to 5500 rpm recommended.
Would this cam be too redical to run with a mild TPI setup on the street?
If it would work I might build a 1975(block) 355 with Trickflow heads and use this cam. Then modify my center bolt holes on my TPI intake to fit.
Maybe 9.3 to 1 or so. Sound OK?
Thanks!
Ernie
Old Aug 16, 2002 | 06:05 PM
tpi_roc's Avatar
I think thats a bit much not only for "Streetability" but you're almost over shooting the power range of a TPI setup. Not so much the duration (which is high) but the LSA is pretty narrow, that would be better suited for a 383 or a super high revving (miniram?) efi setup
Pac J
May 17, 2020 10:44 AM
no green
Jan 9, 2016 09:22 PM
