Is this a good fuel pump to get??
Old Sep 6, 2002 | 02:27 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
http://www.racetronix.com/product/RX..._Pump_Kit.html
Also which pump should i get?
GSS307M
or
GSS340M
I assume GSS340M is to much for a lightly moded 350.
Old Sep 6, 2002 | 02:39 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I'd get the 340 (did actually). I got it because I plan on going to forced induction later, but for an extra ten bucks you might as well upgrade. Besides, gives you a little room to grow...
Old Sep 6, 2002 | 03:01 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
On there website it says the Walbro GSS340M pump is rated at 60psi+. So it won’t matter running it at 40 PSI? I don’t ever plan on upgrading to a blower or anything but I do want a really good pump.
Is the only difference between the Walbro GSS307M pump and the Walbro GSS340M pump pressure? Or will one last longer or something?
Old Sep 6, 2002 | 06:50 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
All I want to know if there is such a thing as having too powerful of a fuel pump. I have a 350 with the modes in my sig and I was thinking of getting the Walbro GSS340M is that too much for my engine???
Old Sep 6, 2002 | 08:27 PM
Car: 86 Cutlass
That fuel pump's not going to be too much for your engine. It works fine with my 350.
Old Sep 17, 2002 | 02:19 AM
PerthZ28's Avatar
TPI fuel pumps
Does anyone know what the rated flowrate of the TPI in-tank pump is - gals per hour or litres per hour etc??
Old Sep 17, 2002 | 11:20 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
The GS340 pump with the hot wire kit is good for 10's
Oh and the GS340 flows at 255 liters per hour and at 50 psi with 13.5 volts applied to the pump it flows @ 65gph
Kat
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
