functional shaker tpi
Old Sep 17, 2002 | 01:46 PM
karrlives's Avatar
i have a shaker i am looking for some device 2 make it 100 %functional with my 350 tpi motor
if any one out there knows if there is somethin on any web site please let me know
thanx
its for a 87 gta trans am
350 auto
Old Sep 17, 2002 | 03:44 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I don't think there are any companies that make a kit for it. Your best bet would be to find somebody who could fabricate you a setup to work.
Old Sep 18, 2002 | 11:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Uhm.... the point of a shaker hood is the cowl is connected to the carb. With a TPI setup there is nothing for the cowl to connect to.
Old Sep 19, 2002 | 10:22 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
unless of course you had tubing ran around from the tb to the hood with a flat filter on top similar to the late model ram air setups
I've thought about it since I am stuck with a 4" cowl and don't need the clearance with Tpi after converting from carb.
colton_carlson
Mar 8, 2019 12:21 PM
Cornholio7979
Sep 20, 2018 02:31 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
