LT1 TB on a TPI??
Old Sep 25, 2002 | 12:01 PM
5L EaTeR's Avatar
LT1 TB on a TPI??
hey guys,
i was wondering if there was any way to convert the lt1 TB's to work with a tpi system? im asking mainly cause i can get a great deal on a 58mm TB from an LT1, but i know it wont work with my 383 TPI. is there anything i can do/change to get this piece to function on my car???
thanks
Damien
Old Sep 25, 2002 | 05:07 PM
bigals87z28's Avatar
Car: Check The Sig
i did a search on this yesterday... the tps is different and there is no TV cable... the trans's in lt1's (except 93) are comp controled... if the tb is for a 92-93 vette or camaro, u might be able to work something out.... but its not gunna work if its for an later lt1
Old Sep 25, 2002 | 06:28 PM
5L EaTeR's Avatar
****, alright thanks man.
Old Sep 25, 2002 | 07:56 PM
89Irocz23's Avatar
You can use a lt1 throttle body on a tpi, but you will have to cut your old tps and Iac connectors off and slice into the connectors on the lt1 throttle body. The tv cable connects to a bracket, but it will work with a lt2 tb.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Sanjay
Aug 12, 2015 03:41 PM
