Superram/ Miniram/ or port match intake,runners, plenum?
Old Sep 30, 2002 | 08:31 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Alright I need opinions/advice. Got a L98 w/ 3.73
gears, an edelbrock dual timing chain,D-1SC procharger@ 8lbs of boost,30#injectors,a 3core intercooler, TCI-breakaway converter, B&M flexplate, Trans-go shiftkit. Now I was wondering if it would be best to get a superram, miniram, or get some slp runners and port the crap out of em along with my intake and plenum? Money is an issue, so if you could be blunt i'd appreciate it. What kind of power gains are we talking here? Thanks
If it helps 343RWHP/375RWTQ @ 5000+ft.
Old Oct 1, 2002 | 01:46 AM
89ReDIrOcZ's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7L 350 TPI
Transmission: 700r4, Shift Kit
u got a PM
Old Oct 1, 2002 | 01:06 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
This is a dangerous question to ask. There are many, many arguments over which one is better. Here's a quick pointer.
StealthRam, LT1 intake are not emmissions legal. The both flow much better than TPI in the upper RPM range.
SuperRam is in the middle, good torque and carried till almost 6k rpm.
LTR are a lot of torque, but not much at the high end.
Mini-Ram I don't think is emmissions legal, but it might be. Overpriced LT1, unless it is emmissions legal.
Go look at the price for all of them. Decide on where you want your power, daily driver weekend racer, drag track, or circle track racing. Then let everyone else know what you want/have, then you will find out. It all depends on what the rest of the engine is made to do.
Old Oct 1, 2002 | 01:52 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The Super Ram is the only one other than stock TPI that allows you to retain the EGR. Mini Ram, LTI or Stealth Rams do not.
LT1Formula
20
Nov 14, 2015 12:02 AM
italiano67
Aug 31, 2015 06:04 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Jake_92RS
Aug 11, 2015 10:39 AM
