Will my same set of headers work with Vortec heads?
Old Sep 30, 2002 | 09:51 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I have a set of Doug Thorley headers that were on the stock TBI heads, and now they are on the Sportsman200s. Will these same headers work if I go to the cast Vortec heads?
I saw a post where the stock manifolds will not work because they use the second outer most hole on the rear but the headers use the inner most hole which is the only hole on the Vortecs, so I should be ok I think, but want to make sure.
Old Oct 1, 2002 | 12:44 AM
u r sofa king we tah did's Avatar
i think they would work, ive never seen thorleys but if the mouting filange is big enough you could always drill a new hole.
Old Oct 1, 2002 | 04:28 PM
davehamilton's Avatar
Hello, The bolt pattern is the same, but the exhaust port is about 1/8 inch higher on the vortec heads, so they wont line up the way they are-- You can elongate the holes downward in the header flange 1/8 inch- Now you can slide the header up the 1/8 inch on the head and tighten it down and you are lined up perfect. If you lay a vortec gasket over your headers you will see how far off they are. Later, Dave
Old Oct 1, 2002 | 08:05 PM
2QUIK6's Avatar
Thanks ya'll. I think I should be ok because the exhaust tubes on the Thorley's I have are a little bit bigger in diameter than the TBI exhaust ports were and currently the Sportsmans are "D" shaped ports and they work ok on them too.
Old Oct 2, 2002 | 09:46 AM
SQUIRLEYMOFO's Avatar
Dave you sure about this?? I had several sets of vortecs I sold and not noticed this the intake ports sure but the exhaust? I have a set in the garage I'll have to see how they match a set of 1 3/4" hooker longtubes ......
Old Apr 11, 2008 | 08:00 PM
mattjw's Avatar
Re: Will my same set of headers work with Vortec heads?
He is absolutely correct.. I ran into the same problem. I was never able to find an exhaust flange with the bolt holes corrected for vortec heads.. Luckily my buddy is skilled with auto-cad and has a connection to a machine shop with a water-jet.
I know that I've taked a picture that demonstrates this but I can't find it anywhere.
-Matt
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
