TPS Voltage & IAC Valve
Old Oct 5, 2002 | 10:18 PM
sub's Avatar
sub
https://www.thirdgen.org/newdesign/tech/tpimod1.shtml
TPS Voltage- It "must" be right on, or your engine will not be running at its peak potential. It must be read with a digital VOM and set accordingly. This is outlined here.
IAC Valve- This determines your engines idle speed, and it also must be set correctly or you will be experiencing idling and low speed drivability problems. This is outlined here.
It's not actually outlined anywhere ... can anyone point me to a good read on how to do these things and what it is? Thanks
Old Oct 5, 2002 | 10:22 PM
Boxeat2469's Avatar
It is outlined, you just needed to look in the technical articles section. Here it is https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Oct 5, 2002 | 10:35 PM
sub's Avatar
sub
Thanks :hail: ... wasn't working for me earlier for some reason, bad link maybe? Woo, more tech articles! :lala:
New2Chevy
Sep 28, 2015 12:35 AM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
