383 Stroker
383 Stroker
HEY GUYS,I AM BUILDING A 383 STROKER WITH 8.5 FORGED PISTONS,THE NEW VORTEC TPI INTAKE MANIFOLD,A SET OF MODIFIED VORTEC HEADS,52 MM THROTTLE BODY,EDELBROCK TES HEADERS,THE LARGER TPI RUNNERS AND A PAXTON SN-93 SUPERCHARGER, AND A COMP CAMS 260 AH-14 OR A 268AH-14 BLOWER CAM.I AM WONDERING WHAT SIZE FUEL INJECTORS TO USE ON THIS ENGINE. THANKS,,,,SCOTT_OVERMANN@TRIHEALTH.COM
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
tricky
i'm going to say it depends on the ammount of boost you will be running.... when it comes to foced induction, thats were the learning cure went the other way for me... lol!!!
if i had to pull a number off the top of my head i will say 30lb.......
this way you know if you decide to run more boost you wont have to buy bigger injectors.....
again, don't qoute me on that......
be sure to get a custom chip so you know the a/f ratio is right on, belive me, you don't want to go lean with sc.......
later
later
here do it correctly
http://users.erols.com/srweiss/calcpchg.htm
http://users.erols.com/srweiss/calchpaf.htm
http://users.erols.com/srweiss/calchpb.htm
http://www.rceng.com/technical.htm#WORKSHEET
http://www.turbofast.com.au/autronic/techdata.html
http://www.holley.com/HiOctn/TechSer...l/Artcl07.html
http://www.rbracing-rsr.com/fuelinjectors.htm
LT1Formula
Oct 8, 2015 08:34 PM
