85-88 and 89-92, plenum and runner difference
Old Oct 26, 2002 | 03:33 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Whats the difference between the 85-88 and 89-92, plenum and runners? And how do I know which to use? My 350 TPI is out of an 87, but i'm going to have the 88 and up serp belt setup. So is that going to make a difference? Also, I'm going with vortec heads and SDPC TPI baseplate. Figured i'd port my plenum and get bigger runners, but dunno which brand and what year will go well with ported plenum and the SDPC TPI baseplate.
Old Oct 26, 2002 | 09:06 PM
xformula79's Avatar
Pre- '89 runners had provisions for the CSI (cold start injector). It was eliminated in '89 along with a prom change. I believe the plenum is the same for all years. You need to use pre '89 aftermarket runners if you are using the stock '88 tpi prom w/CSI. All aftermarket runners are pretty close in flow performance. I would say get the least expensive - it may be the SLPs.
Old Oct 26, 2002 | 11:08 PM
GTAracer's Avatar
Pre 89 plenums have provisions for cold start injector as well
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
greenyone
Sep 2, 2015 03:39 PM
