cannot figure out hesitation??
Old Oct 27, 2002 | 06:24 PM
jcsws6's Avatar
Please help give me some insight into this issue. I have a hesitation in gear when you go to about 3/4 power, for about 2 seconds (like it studders) then away I go. This weekend I did a header/cat-back install, so I pulled all my plugs (two months old) and checked my wires. Everything on the car checks out (full tune up 2 months ago, replaced everything), but I can not lick this one. Fuel pressure is right at 48PSI and doesn't drop off. Could this be bad fuel injectors?? Other than the hesitation it runs perfect.
thanks
Old Oct 27, 2002 | 06:34 PM
xformula79's Avatar
Probably a MAF or TPS related problem. Does the car run good otherwise?
Old Oct 27, 2002 | 06:36 PM
jcsws6's Avatar
the only other problem the car has is on cold starts you have to give it gas or it will die, but after 5 seconds or the second start its fine. MAF sensor is a year old and checked the tps today and it was great.
Old Nov 1, 2002 | 12:20 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
maybe
I had a similar problem with a little hesitation but it was immediately upon depressing the accerator from idle. I did the tuneup, checked the TPS, checked vacuum hoses and nothing. Finally my stock ECM went out so I replaced it and bought an Ed Wright fastchip at the same time, VOILA, no more hesitation. Sorry I can't be more specific but thought this might help.
junior419
Apr 7, 2025 11:35 AM
69GTOby
Apr 18, 2016 02:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
