Variable Speed Sensor
Old Nov 7, 2002 | 11:43 AM
John Manson's Avatar
Hi, All. I am down to the last item on my TBI to TPI conversion list and it is proving to be hard to find? I need a TPI vss that is the correct/same size as the current TBI vss. The car is a 1991 5L TPI now. The TBI vss is electro-mechanical while the TPI vss is a permanent magnet generator. Help!!!
Old Nov 7, 2002 | 01:58 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
What ECM are you going to run after
the conversion? You may be able to
use the non-magnetic input channel
of the '7730 ECM (EPROM change) if
that's what you're using?
(The MAF to MAP tech article has info
on the EPROM change.)
mike
Old Nov 11, 2002 | 01:00 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Variable Speed Sensor
What transmission are you running? What year is your vehicle?
Eric2ndGen
Nov 5, 2015 01:51 PM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
