Aftermarket Injectors
Old Nov 13, 2002 | 08:53 PM
giff's Avatar
Car: 91 G92 Formula, 35k original miles and owner
Transmission: 5 speed
GETTING MY MONEY'S WORTH OUT OF THIS FORUM GUYS..
I'VE HEARD FOR YEARS THAT THE STOCK GM INJECTORS ON THE TPI MOTORS ARE JUNK ? THEY BURN UP (HAD TO HAVE SEVERAL REPLACED UNDER WARRANTY YEARS AGO) AND THEY DON'T FLOW AT THE SAME RATE ???? WHICH RESULTS IN POOR THROTTLE RESPONSE AND ULTIMATELY HURTS POWER.
I'VE OFTEN THOUGHT OF BUYING A MATCHED SET (FLOW RATES ARE VERIFIED AS THE SAME) OF INJECTORS FROM SOMEONE LIKE LINGENFELTER ETC.
LOOKING FOR SOME FEEDBACK ON THIS ISSUE..
GIFF
Old Nov 13, 2002 | 09:25 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You can buy LS1 injectors apparently for fairly cheap.
Old Nov 13, 2002 | 09:34 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Will LS1 injectors on a stock motor help any? I don't think so however I know nothing about injectors as far as modding goes.
Old Nov 13, 2002 | 10:00 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I don't think the LS1 injectors will work, they look to be talller. Injectors off an LT1 would work though.
I use Accel's cheaper injectors, they are around $220 a set. Have had no problems with them in a few years of use.
Old Nov 14, 2002 | 02:39 AM
Bort62's Avatar
Here we go again...
YES ls1 inj will work. So Will Lt1, Hell, So will just about all the production injectors out there.
NO stock inj are not junk
Merely Changing injectors from stock to something else of a differant flow rating is going to screw up your fueling signifigantly. You need at least a change to the PROM to Compensate.
There is no performance advantage in going to a larger injector on a stock engine unless you plan more extensive mods in the future wich will warrant the larger injectors.
The best bet for a set of high Milage L98 injectors would be www.cruzinperformance.com
Get em back for 80 bucks, good as new.
Old Nov 14, 2002 | 07:02 PM
88ViperKiller's Avatar
How much HP you think those L98 injectors can support?
You know the flow rates? I couldn't find 'em...
Old Nov 14, 2002 | 07:07 PM
giff's Avatar
Not looking to increase the flow rate just be more uniform accross the board as far as flow rates. (and more reliable long term)
i got word years ago from a good gm tech friend of mine that they were indeed sh&% and he had seen many replaced.
giff
J-money
Jan 4, 2019 09:45 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
john204481
Sep 7, 2015 03:22 PM
