TPI, MAF and SD swap question
Old Nov 18, 2002 | 08:42 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
hello all i did a search but im not too sure what to search for but here goes.....
the 305 in my IROC is a SD system and also (from what i have read) has some sort of security system in the computer called VATS i think?? well i have a 350 tpi from an 87 im dropping in and i was wondering what i would have to modify in the wiring to get this tpi to work in my harness??? as far as the MAF sensor goes and also the vats? and also will eliminating the VATS mess up my collumn?? would i need a column from a NON-vats car??
Old Nov 18, 2002 | 08:56 PM
Guest
Guest
Posts: n/a
I think youre doing it backwards.
It'd be easier to leave the wiring and all in the car, drop the 350 block and heads in there, bolt up your TPI setup, use the 350 injectors (if it has them anyway) and run a 350 chip in the computer. That way, you arent messing with the wiring at all, dont have to stick the MAF in there, or anything like that. Some people might suggest using a 350 knock sensor, but I havent found any problems with not doing that.
Old Nov 18, 2002 | 09:00 PM
stevver84Z's Avatar
ok i think im gonna do that, seems to hard to convert the wiring, thanks for the reply
Old Nov 18, 2002 | 09:03 PM
stevver84Z's Avatar
aren't the intake bolt patterns different though??
Old Nov 18, 2002 | 09:29 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Nope both are center bolt heads
The intake will swap over fine
Kat
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
