who makes the best runners
Old Nov 28, 2002 | 02:24 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
in your opinion who makes the best runners for a high rpm car (over 5000 rpm peak).
Old Nov 28, 2002 | 02:39 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
AS&M are great tpis are alos very good...but for higher rpm id say te slp siamesed
Old Nov 28, 2002 | 04:20 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
i think that the SLP are the best for the money. I believe $350 if way too much to spend on runners for the AS&M because a holley stealth ram is only shy about $150. And you can pass emissions with the stealth ram, it just needs a little more tuning.
Old Nov 28, 2002 | 07:20 PM
firebirdkid's Avatar
you can get a set of runners for 250 from thirdgenresource.com thats what im getting..
Old Nov 28, 2002 | 08:06 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
250 really? Wow that's a GOOD price for large tubes... I'm currently torn between a Superram or just getting a ported plenum w/ LTR's and an aftermarket base like the big mouth
Old Nov 28, 2002 | 08:17 PM
xanax's Avatar
get the stealth ram, this **** is bad. even putting it on a stock engine it wakes your car up bigtime. with a six speed put in it is even better holding it to 5800rpm and making good power all the way up. i am getting some 4.10 gears next, that should be a huge difference.
Old Nov 29, 2002 | 01:35 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
with a stock motor, i think the stealth ram would not help, say a stock 305tpi as the limiting factor on that motor is the cam. And holding a stock motor to 5800 rpm is not suggested. to tell ya the truth about 4.10's, unless your car makes power at the high rpm range, i think bigger numerical gears will hurt ET times.
Old Nov 29, 2002 | 05:39 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Whuzzat?
A stealthram on a stock 305? No way. I believe Xanax was implying a 350 weren't you Xanax? =)
Hehe - aw man I WOULD get the HSR or the Mini or the LT1 but the Superram is smog legal and I want an emissions legal intake. I figure if I'm going to drive a 350 these days the least I can do is obey sniffer laws =P
Old Nov 29, 2002 | 06:03 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
You can tune a miniram, HSR, LT1, to pass emissions, maybe not CA emissions without serious tuning, but you can pass most state emissions with tuning. Hey I'm passing with my miniram
Old Nov 30, 2002 | 09:48 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: who makes the best runners
me and swapmaster
https://www.thirdgen.org/techbb2/sho...ghlight=runner glue&pagenumber=1
Old Nov 30, 2002 | 10:02 AM
c4boom's Avatar
Engine: l98 and lo5
yes but they are untested there for not proven and if i was to do that i would use a set of slp's
Old Nov 30, 2002 | 07:07 PM
91banditt2's Avatar
Engine: 5.7 HSR
[i] not proven [/B]
you are correct on that.but in my opinon all of the aftermarket LTR up grades are way over priced.i'm not spending $200-$500 on just runners or $400-$500 on a new intake base.when i can use a LT1 intake or a HSR for alot less.
not trying to start a fight just voicing my opinon
Old Nov 30, 2002 | 07:34 PM
c4boom's Avatar
Engine: l98 and lo5
i am planing on doing the same thing for my track car but it will pbly be to a set of slps and i am going to port a big mouth
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
italiano67
Aug 31, 2015 06:04 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
earlpote
Aug 28, 2015 10:42 AM
