Fuel Pump relay replacement?
Old Dec 7, 2002 | 01:17 AM
Bruce89TA's Avatar
Car: 89 Firebird T/A
So I've got a fuel pump relay with a burnt up connector. I'm thinking I should replace it but looking online, the relay socket is $30 for a GM replacement. I have a couple relays (like the high speed fan relay and the maf power relay) sitting around.. Anyone have any reason for me not to replace the existing relay and socket with this one? As long as I can figure out the pinouts, I have no issues with the actual procedure, I'm just wondering if the relays are spec'd differently and when replacing one with the other, will I run into problems? Please let me know.
-Bruce
Old Dec 9, 2002 | 09:32 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Fuel Pump relay replacement?
-Bruce
The MAF relay is the same, the MAF burnoff
relay is essentially the same, but one of the pins
is not in the harness and not tested at the factory
for the relay..
HTH
mike
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
