Fuel lines, thread sealant?
Old Dec 19, 2002 | 01:17 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Are you suppose to put thread sealant on the fuel lines where they connect to the TPI fuel rail?
Old Dec 19, 2002 | 02:03 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
No, but you should make sure the o-rings are in good shape. If they are not they need to be replaced.
Old Dec 22, 2002 | 01:33 PM
4L60bliss's Avatar
Like Ed said, no sealant. These are "o-ring flare" setups and use the o-ring to seal the connection. Also, make sure you use the correct o-ring. They MUST be fuel line o-rings for that application. Using regular o-rings from Pep-boys or so could cause leaks.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
