o-ring part numbers
Old Jan 7, 2003 | 10:21 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
o-ring part numbers
i remember seeing some posts asking about o-rings for the fuel system. while i was at the dealer i got these.
22514722 - fuel line supply side for TPI
22516256 - fuel line return side for TPI
17111954 - cold start injector o-ring kit for TPI
17113544 - injector o-rings top/bottom set for TPI
Old Jan 8, 2003 | 11:15 AM
Vader's Avatar
Thanks. I had the injector 'O' ring set p/n in my archives, but not the rest. I do now...
Old Jan 8, 2003 | 11:45 AM
Fastcamaro87's Avatar
im not sure if the dealer has it or not, but where i work we have a complete kit for the fuel rail, ill get the part numbers for u 2morrow.
Old Jan 11, 2003 | 09:59 PM
jonarotz's Avatar
Car: 91 Z28
Would you happen to know the part # for the o-rings for the pipes that tie the fuel rails together?
Old May 18, 2003 | 07:53 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
i would also like to know this???
Old May 19, 2003 | 02:09 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Just get the old ones that you need to replace and go to your local hardware store and match them up with some new ones. Just make sure that the o-rings that you get are made of viton or something else that is resistant to petroleum (aka gas). Did that when I did the injectors on my GTA and had no prob and saved a little $$$ and time in the process.
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
