Fuel Pressure Setting?
Old Jan 13, 2003 | 07:20 AM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Ok... this weekend I put my plenum and fuel rails back on the car...there was some initial hesitation on start up (the starter would click but no go..it was a lose ground I believe)
Anyway... fired her up and set the fuel pressure at around 39-40 psi at idle. She idled nice and smooth....
The question I have is... when I was revving her up I noticed that the fuel pressure would shoot up from 40 psi to about 48 psi...this was at about 2500 rpm's. Is this normal? What should it be? And what kind of pressure should I see at WOT??
I know that the injectors can handle pressure up to 80 psi as that was what they were pressure tested at Cruzin Performance.
Other than that she idled and revved really nice....flowed and cleaned injectors and a ported/polished plenum does wonders for idle
Old Jan 13, 2003 | 08:40 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
87ROCZ....did you set the pressure correctly? This is how it should be done as far as I know....disconnect the vac line to your regulator, put your gauge on the car, and turn the key to the on position. Just set it like that...I'm pretty sure that removing the vac line simulates a wide open throttle condition. Also don't go too rich. I had mine set at 50lbs and found out that I was running too much pressure so now I backed it down to 45psi instead.
Good Luck
Old Jan 13, 2003 | 09:14 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Disconnect the vac line, plug the hole where you disconnected it from and read the pressure with the engine at idle. Shoot for 43.5 psi.
Old Jan 14, 2003 | 06:50 AM
87ROCZ's Avatar
Cool
So if I shoot for 43.5 psi with the vac line off..what will the pressure be once I connect the vac line?
And how do I do it? With the engine running and idling?
Old Jan 14, 2003 | 08:57 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Just hook your gauge up in the morning before you fire it up for the first time, disconnect the vac line, fire it up and adjust from there. With the line connected the gauge should read about 5 less psi.
Old Jan 14, 2003 | 09:06 AM
87ROCZ's Avatar
Cool... understood
So in idle with the vac line connected she should be sitting around 38-39 psi...
Gotcha....
Thanks for the tips!!
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
