ZZ4 cam good for my 305
Old Jan 27, 2003 | 03:26 PM
bigals87z28's Avatar
Car: Check The Sig
just what it says above... my friend has a ZZ4 cam and i wana know if it would be a good match for my 305...i plan to have some head work, and im porting out the plenum and runners... also have planned full exhaust... no 350 stuff.. just whats good for the 305 for now... he needs to know if i want it.. or hes gunna sell it
Old Jan 27, 2003 | 06:48 PM
86 IROC's Avatar
IMHO - I think it is a great cam for 305 TPI's. As with anything on these cars, PROM tuning will make the most of the cam swap.
Old Jan 27, 2003 | 08:59 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
what do you guys think the horsepower gain would be? would 30-40 hp be a reasonable guess over a peanut cam car?
Old Jan 29, 2003 | 06:55 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
well moving from the lt1 cam to the zz4 cam in my 350, i gained .2 in the quarter. that's about 20 hp
Old Jan 30, 2003 | 10:19 AM
Car: Check The Sig
sounds good to me... i got the cam now, and now i need to know what else i need for it to work without problems... Would it be smarter to go get SR torquer heads, or would it be cheaper to get my stock heads port and polished and milled for a bigger spring seat? and if i get the torquer heads... could i reuse the rocker arms?
Old Jan 31, 2003 | 12:20 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The ZZ4 cam has too much lift for the stock heads.
Old Jan 31, 2003 | 05:52 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Okay then ( just curious what I have to do to the heads for them to fit . Because there are other members running this cam ( I hoped they would reply) with the 305.
Thanx again
84z96L31vortec
Aug 20, 2017 12:16 AM
italiano67
Dec 11, 2016 09:21 AM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
