can the HSR be modifed to work with vortec heads
Old Jan 31, 2003 | 09:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
Like the subject says. can it be possible to get this to work. would the vortec heads work good with the HSR if they bolted up
Old Jan 31, 2003 | 09:50 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It can never bolt up. Here's a picture why, it is with a standard carbed intake but it makes no differance, the HSR is the same port and bolt pattern wise.
Attached Thumbnails can the HSR be modifed to work with vortec heads-vortec1.jpg
Old Jan 31, 2003 | 09:58 PM
Boxeat2469's Avatar
Never say never. This is straight off of GM's website
The Vortec heads have a unique eight-bolt pattern for the intake manifold. Earlier twelve-bolt intake manifolds can be used, but the heads must be drilled and tapped for this configuration. Use gasket (P/N 10148096) as a template to lay out the bolt hole locations for the 3/8-16 bolts. GM Performance Parts' Vortec dual-plane aluminum intake manifold (P/N 12366573) also may be used in applications where a dual-plane manifold is acceptable.
Go here http://www.gm.com/cgi-bin/pr_display.pl?367 to read the rest if you want. But as the picture John posted shows, some intakes don't have enough material on the edges to cover the ports. I don't know whether the HSR would work or not, but some intakes do work.
Old Feb 3, 2003 | 03:04 PM
Jza's Avatar
Jza
HSRs have very little extra material around the edges of the ports. You'd need a little aluminum welded to the intake to get a Fel-Pro 1206 to match up and have enough meat to seal, so a high-port head would be worse.
Old Feb 3, 2003 | 03:37 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Does GM still see that ram-jet intake?
Old Feb 3, 2003 | 04:05 PM
Jza's Avatar
Jza
Good point Ed. That's the way to go if you're set on those fastburn heads. It's a pretty underrated intake IMO. I'll be installing a RamJet topped ZZ4 in a friend's car later this fall if he'd quit screwing around with the little crap.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
