Heater control valve removal
Old Feb 20, 2003 | 07:35 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I've seen a few people mention that they have removed their heater control valve. Just wondering what this does? I'm guessing that it won't lock hot water in the heater matrix?
RMK
Old Feb 23, 2003 | 11:16 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
TTT
I'd like to remove this to clean up my engine bay also. with the LT1 intake I have coolant hoses running everywhere.
Old Feb 25, 2003 | 10:37 AM
Jza's Avatar
Jza
Well, you can either have coolant running through your heater core all the time, or never. Or you can leave it in and have coolant flow only when it's needed. Simple as that.
Old Feb 25, 2003 | 02:02 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I removed it on both of my cars. In the summer my GTA runs a little hot, but I don't think it's due to removing the diverter valve. In my IROC it's also gone, and the car runs as cool as a cucumber.
Old Feb 25, 2003 | 06:51 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
It won't make any effect on your cars cooling. With the valve in, coolant goes to the valve, and if it's open, coolant goes through the heater core and then dumps out into your waterpump, or right side radiator tank (depends on year/engine combo). If the valve is closed, it skips your heater core, and dumps out to (again) the water pump or radiator end tank.
Keeping the valve in will make your AC run a little better, but that's about the only benefit.
I can tell you the plastic they're made of gets brittle with age, and when it breaks (mine did 2years ago), your car will puke all it's coolant out that hose in 2 minutes flat.
I would keep it in, or replace it if it's bad, but it's really a matter of personal opinion. If memory serves me correctly, it's a $20 piece of stupid little plastic
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
3rdgenparts
Aug 8, 2015 07:09 PM
