any benefits to porting the stealthram??(GMhi-tech)
Old Mar 10, 2003 | 08:39 PM
88GTA3555SPD's Avatar
Car: 88GTA
Engine: 383
Transmission: t5 junk
i noticed in the gm hi tech magazine where they show the installation of the stealthram on an 86 iroc that they used a dremel to port the runner entry to the lower intake a few inches down and brought the center sections to a peak instead of 1/8-1/4 flats
im about to install my stealthram in a week and does anybody think there will be any noticable benefit to doing this or it would be a waste of time and it should be extrude honed by a shop
Old Mar 10, 2003 | 08:56 PM
BOTTLEDZ28's Avatar
Transmission: A4
I doubt you will be able to feel or see any HP gain from doing that small dremal job. The reason for it was to ensure the incoming air has a smooth flow path into the intake. Basically, you want smoth radius' around all corners. Air will always flow faster when it has the least amount of sharp corners to make. I will be installing my HSR in the coming weeks and will be doing this work as well. Yes. I know I said you proberbly wont feel any difference, but the engine.
Old Mar 11, 2003 | 12:11 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Hmmm no you won't feel it - but like a lot of things you don't feel, it will be there improving performance just slightly. The HSR is such a damned monster out of the box, I think one would have to do some radical porting to notice performance above a stock unit. For your 355 I don't think theres much justification unless you're just a freak (and theres nothing wrong with that!)
Just depends whether or not you want to spend the time porting or just slap the **** on and go. I would not extrude hone it, that is very expensive and not needed for your displacement.
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
