AFPR question
Old Mar 16, 2003 | 11:25 AM
Gomer's Avatar
Car: 89 IROC
AFPR question
I have a 89 IROC 350 and I just replaced my injectors with 22# SVO injectors. I don't think I need to change the injector constant in my prom since these are rated the same as stock. But I do have to drop the fuel pressure since these injectors are rated 22# at 39psi. Is that right?
So i installed my Accel AFPR and started the car. The fuel pressure was sitting at 39psi. I then disconnect the vacume line from the plenum to the AFPR and the pressure jumps to 50psi. The AFPR screw is already backed out as much as it will go. I drove the car around and the BLM's are sitting pretty close to 128 and the O2 at WOT is about .85
I'm just concerned because I read that the fuel pressure should be 39psi with the vacume line disconnected, not 50psi. I'm not sure if I should just leave it alone or what.
thanks
Old Mar 16, 2003 | 01:31 PM
Mohammed's Avatar
Car: 88 IROC-Z
Transmission: 700-R4
there is no 91 IROC-Z
Old Mar 16, 2003 | 01:57 PM
Gomer's Avatar
Car: 89 IROC
doh....ment 89...
tonys91rs
Oct 26, 2015 12:11 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
