Sealant for sensors
Old Mar 22, 2003 | 07:09 AM
primo's Avatar
Sealant for sensors
What kind of sealant should i use for sensors on aluminum head and sensors on iron block.
Old Mar 22, 2003 | 07:25 AM
85TPI400's Avatar
I use Permatex white teflon (pipe thread) sealant on all head bolts and sensors that go into water jackets. Works fine for me!
Old Mar 22, 2003 | 08:24 AM
Nasty_Bird_'90's Avatar
Permatex aircraft type sealant. Non hardening, it thickens a little bit a seals perfect. Not all sealants are sensor safe though. You have to use the right stuff b/c most of the sensors ground themselves to the head and if you use something that will create a barrier between the threads of the sensor and the head it won't ground and you will have problems.
Old Mar 22, 2003 | 09:28 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Old Jun 3, 2003 | 01:02 PM
OMINOUS_87's Avatar
What do you guys suggest for the sensors and vaccum niples in the plenum?
I figure I will use the pip sealant on all the sensors that go into block and heads.
Is that ok?
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
