Please Help! ecm question
Old Apr 17, 2003 | 03:59 PM
dramaone's Avatar
Car: 1982 Z28 Camaro
Engine: 1988 350 H.O.
Transmission: TH-350 w/ shift kit/stahl converter
Can I use an ECM from a 88' 305 Iroc w/ tpi on a 88' 350 Iroc w/ tpi ?
Old Apr 17, 2003 | 04:16 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The ECMs are the same. Only the Memcal is different (what most people call the "chip").
Old Apr 17, 2003 | 04:23 PM
dramaone's Avatar
Thank You, I'm about to purchase one on ebay for about 10 bucks, so I am going to have to replace the memcal, about how much do you think the memcal will run me? and do you know where I can get one, also the car itself is not an 88 iroc, its an 82' z28 that originally came with a 305 HO, I swapped the original engine and transmission for an 87 350 HO from a caprice and a th-350 from I dont know what, will any of these details make a difference? Thanks!
Old Apr 17, 2003 | 04:36 PM
Car: Death Mobile
Engine: 666 c.i.
Isn't the 87 a TBI if it came from a Caprice? Are you also installing a TPI intake? If not, then the the ECM won't work. TPI ECMs do not work on TBI cars and vice versa.
Old Apr 17, 2003 | 04:39 PM
dramaone's Avatar
I'm sorry, I forgot to add that the Tpi is from an 88 IROC, Im swapping the rochester quadrajet and intake that came w/ the caprice engine with the IROC TPI, right now the tpi is sitting in my bedroom. Thanks again.
Old Apr 17, 2003 | 04:41 PM
dramaone's Avatar
Its a complete tpi system minus the distributor, fuel pump, and ecm, hence the ecm question, also any tips on a distributor and fuel pump would also be appreciated.
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 10, 2015 08:42 AM
