tpi harness removal question
Car: 1987 iroc
Engine: 434 bbc
Transmission: 350 turbo
i have removed my tpi and harness from a 1987 iroc with a maf 350 tpi.my question is what needs to be rewired besides the wipers and alt.?will the electric fuel pump still work?thanx in advance
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Are you removeing the TPI for good? Are you going to carb or something?? If so, don't even worry about your fuel pump. But yes it will work with out the Harness, you jsut need to switch power to it. But you will need a Good fuel pressure regulator to control the fuel, also I sent you a PM too....Let me know and we can go from there.....
Car: 1987 iroc
Engine: 434 bbc
harness
thanx for the quick response!!yep,its gone for good.i have a 427 bb to install in it.i noticed that the alt. wire went with it too.is that all or is it more?i couldn't get the pm.it told me i had one,but it wasn't there.do you think there is clearance for a tunnel ram with a bb?thanx:hail:
Engine: T.P.I L98.
Transmission: TH350
As for Clearance with a tunnel ram..not a chance! Sorry! No PM eh? I want to buy your Harness if I can..do you have the other engine and parts still?...Please email me with your answers, and with any other questions you may have. kwittmaier@cogeco.ca
Thanks.
Keiran.
Thanks.
Keiran.
Sanjay
Aug 12, 2015 03:41 PM
