set timing, forgot to plug in 4 pin connector...
Old Apr 26, 2003 | 12:42 AM
TPIMonteLS's Avatar
Transmission: Automatic!
Hopefully this doesnt fall under one of the banned type timing questions, its a bit different...
On my TPI Monte which I finally started up tonight after the long swap, I set the timing obviously first then cranked it, it wanted to go but didnt turn over fully. I then realized I didnt plug in the 4 pin connector to the back of the distributor, and then plugged it in. Oops.
My question is: Since I plugged in the brown/black stripe wire by the heater core and cranked it before I plugged in the 4 pin wire on the distributor, would that effect anything? I mean if I would of plugged in the 4 pin first then the brown/black stripe before starting it would it possibly run differently(better? ) or would it have no effect at all? TIA.
Old Apr 26, 2003 | 01:38 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I don't think it will have any effect at all. But maybe try disconnecting your battery (after connector is hooked up) in case it stored an ECM code.
Old Apr 26, 2003 | 01:40 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Disconnecting the 4 wire connector didn't hurt you none. It's just like unplugging it on the old computer controlled carb set-up to do timing, since they didn't typically have the seperate connector the EFI cars have.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Poncho92
Aug 7, 2015 08:15 PM
