88/89 TPI/Prom Differences
Old May 2, 2003 | 07:42 PM
TJs57TPi's Avatar
i read somewhere the difference in the 88 and 89 tpi setup is the 89 has a cold start injector where as the 88 doesnt, however, i have an 89 350 tpi engine out of my old 89 formula 350 i f'ed up, but in my 88 i recently purchased it has the original 88 350 tpi with a cam and headwork, headers and whatever but what are the real differences between the 2 units?
is it worth swapping the 2 setups?
I kept the whole ECM box thing that the prom mounts in, what would happened if i plugged in the 89 ecm and "superchip" and took the 88 one out? would the intake swap be necessary? would i need a different wiring harness?
also before i smashed up the 89 firebird in an accident, i ported the plenum on it, will the 89 plenum work on the 88? i think it looks better too cuz it has smaller lines on the top of it. its also polished
Old May 2, 2003 | 08:23 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Actually if I am not mistaken it should be that 1985-1987 cars should have the cold start injector. 88 on up shouldn't. Someone feel free to step in and correct me if I am wrong.
Old May 2, 2003 | 08:26 PM
87WS6's Avatar
BTW I would be interested in purchasing your extra L98 if you are interested in selling it. I do not need any of the TPI equipment. Just the long block and heads. Maybe the flexplate. PM me if interested.
And your plenums are interchangeable.
Old May 2, 2003 | 08:38 PM
TJs57TPi's Avatar
sorry, yeah u are right, my 88 has the cold start and the 89 does not
Old May 2, 2003 | 08:39 PM
TJs57TPi's Avatar
how much would u give me for it? i was planning on puttin the whole thing on ebay sooner or later, the whole setup
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
