SLP runner's wont seal?? Please anyone!!
Old May 5, 2003 | 06:35 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Intalled the slp runners on the weekend, and the POS runner's won't seal. I keep getting a vacume leak and all of the lines are fine. Any info would help here!! I tried new gasket's, the old gasket's, and new gasket's with gm gasket maker on them I am uot of idea's
Old May 5, 2003 | 08:26 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Letting us know where it's leaking might help. On the plenum or the intake? What intake have you got? I found that the machined surface on the accel base isn't quite big enough for the runners to sit properly. 5 minutes with a grinding tool will fix that problem. Assuming nothing is warped, my guess would be that you've got some sort of similar issue with the parts not matching up perfectly.
Old May 5, 2003 | 08:32 AM
Car: 91Z
It's leaking on the lower rear of both side's, and the base is stock. I am puzzeled here
Old May 5, 2003 | 09:35 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
probably the pos runners themselves not you
Old May 5, 2003 | 12:33 PM
Jim85IROC's Avatar
Yeah, that's got to be it.
I never tried fitting my SLP runners to the stock base, but it's possible that there's still an interference issue. Try to install them without gaskets and see if there's a problem with something interfering or if they are just warped. You need to figure out why they don't fit before you can figure out how to fix it.
Old May 5, 2003 | 12:36 PM
KAOSRacing's Avatar
I've got SLP runners on my stock base and they fit fine. Have you checked the runner surfaces with a straight edge?
Car: 91Z
I have tried with no gasket's in the problem area's. I think I am gonna scrap them an go with the superram!!! Good old cerdit card
Old May 5, 2003 | 04:44 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
What tightening sequence are you using? Try alternating top to bottom and left to right in small increments. Thats what I had to do and I used this stuff called Aviation Form-A-Gasket and have never looked back.
Old May 5, 2003 | 08:11 PM
Jim85IROC's Avatar
You give up too easy. If you can't get these to fit you're in for a rude awakening when you try to get the Super Ram on there. Figure out your problem with these first.
Old May 5, 2003 | 08:15 PM
bigals87z28's Avatar
Car: Check The Sig
i dont know, but SLP's quality isnt as good as it used to be. This isnt the first time this has been brought up on this board. oh well.. just my .02
Old May 6, 2003 | 08:35 AM
Car: 91Z
Trust me I have not given up easy, I have been fighting with this thing for almost a week!! I installed a buddy's super ram in an afternoon with no problems. I am gonna give it one more crack tonight with a friend of the family that has been building engine's and tranny's for over 15 year's, if this does not work, trust me nothing will. I just think with the condition these thing's came in, that it would not suprise me that they would'nt fit!!
Old May 6, 2003 | 10:06 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
For three days I thought I was fighting the same battle with my SLP runners and a vacuum leak. It turned out the cold start injector needed trimming because the fat runner interfered with the CSI bracket. 10 seconds with an angle grinder, BAM! Vacuum leak fixed.
Guess that doesn't help much on a 91 though...
Old May 6, 2003 | 10:57 AM
Car: 91Z
No, but thank's for the info guy's. I think it could be one of the injector o-ring's from when I popped the rail up 1/2" to get the pass. side runner in Hopefully that's what the problem is!!
Old May 6, 2003 | 11:00 AM
Car: 91Z
bnoon, Just curious, what was your car idleing at with the injector air leak.
Old May 23, 2003 | 06:48 PM
akobak's Avatar
leak
My csi is leaking and when I first start the engine I can hear it leaking untill it heats up then the noise seems to go away. It idles high around 1000 but after a minute or two its back to almost normal. If you have any feedback on the email me. thanks andy akobak@kent.edu
Old May 24, 2003 | 07:16 AM
bnoon's Avatar
Yes it idled, but VERY poorly. If I revved it, it would come down, hunt a little bit, then stall. I found the leak with short blasts of carb cleaner. Small sprits of carb cleaner towards a gasket, then wait for a slight jump in RPM. Keep trying other gaskets unti you find one that makes the idle go up a bit, then settles back down.
Old May 24, 2003 | 08:58 AM
kevinc's Avatar
Car: 1982 Z28
Ditching a pair of runners, going to Super-Ram, expecting that monster to be easier assembly?
This is going to be a fun show.
Old May 24, 2003 | 03:19 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
If you don't have anything to add to a thread other than a rolleyes smiley, you should go find something else to do.
91wtROH17's, have you straight edged the runner flanges? And which runner gaskets are you using? Are you using any kind gasket maker or glue?
Old May 24, 2003 | 03:27 PM
Car: Check The Sig
Re: leak
my car runs at about 1000 rpms to start with, then goes down to about 750 too... is it cause its cold, or do i have another problem? sorry i didnt mean to hijact this post.
Old May 26, 2003 | 06:39 AM
Car: 91Z
Thank's acceld, I used some GM gasket maker on the lower gaskets and put new one's on the top aswell. Work's great now. Those SLP runner's are crap to work with. Ohh ya and Kevin, I have installed a superram, it's not fun, but also not that difficult.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
