Completed: LT1 Heads on a GEN1
Old Apr 1, 2005 | 01:03 AM
  #101
tpi_roc's Avatar
Ok I started by locating the hole, then predrilled it and increased bits untill I got to half inch, then I went with the 3/4" bit. Word of caution, learn from my mistake, do NOT use a hand drill.
Old Apr 1, 2005 | 10:37 AM
  #102
my89gta's Avatar
sorry
Old Apr 3, 2005 | 11:23 AM
  #103
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
are the lt1 intake bolt pattern the same as the 87-95 sbc pattern or even an older pattern!!!
Old Apr 3, 2005 | 12:38 PM
  #104
tpi_roc's Avatar
www.lt1intake.com
Old Apr 4, 2005 | 03:12 PM
  #105
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
U plan on mounting any accessories to the front of that motor??? I think you should have tapped them in the rear of the heads....
Old Apr 4, 2005 | 03:17 PM
  #106
tpi_roc's Avatar
No sir
Old Apr 18, 2005 | 01:11 AM
  #107
tpi_roc's Avatar
Distributor hole is drilled in the otherwise stock intake. I hope to have this engine in the car next weekend.
Old Apr 18, 2005 | 01:44 AM
  #108
Igor's Avatar
Engine: 383 carbed sb
Transmission: th350
... this is a WICKED post. Specially for a guy like me that has a complete LT1 topend for parts!!!
Keep us posted, great work man!!!
Old Apr 23, 2005 | 01:34 PM
  #109
SOLOMOTORSPORTS's Avatar
Car: 88 GTA
Engine: 99 LS1 346
What kind of headers do you run 3rdgen or 4thgen?
Old Apr 23, 2005 | 09:57 PM
  #110
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
im new to these forums. but here goes . i thought of this same idea when i saw how cheesey the tapping into the manifold looked. i used a set of zz4 heads, and mapped it out where i could go through the stock acc bracket and the head. if i can figure out how to post pics i will.
Old Apr 23, 2005 | 10:07 PM
  #111
tpi_roc's Avatar
you want thirdgen headers
Its getting installed tomorrow, so here's the last pic before it goes in.
Old Apr 24, 2005 | 02:20 AM
  #112
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Looks nice, I want to hear how it turns out. Where did you get to weld up the heads? Like what kind of shop? All the welding places around here tell me they don't want to deal with it for liability even though I say I understand the risks.
Those look like SLP 1 3/4" as well, right?
Where did you get those 90* bends from? Those are nice looking.
Old Apr 24, 2005 | 02:36 AM
  #113
tpi_roc's Avatar
Yes they're SLPs, earls russel and nonammers all make 90° AN fittings. Try summit/jegs/whoever. Also another source for cheaper brass fittings is hydraulic supply shops and hose builders.
Old Apr 27, 2005 | 07:44 AM
  #114
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
TPI-ROC, you've got suuuuum patience. It came out awesome, and I can't wait til you dyno that thing. Excellent!
Originally posted by tpi_roc.Its getting installed tomorrow, so here's the last pic before it goes in.
Old May 3, 2005 | 04:25 PM
  #115
tpi_roc's Avatar
Update:
The engine is in but hasn't ran yet. Doing finishing touches this week.
Old May 9, 2005 | 12:08 AM
  #116
tpi_roc's Avatar
She lives
The engine ran today for the first time. They deffinatly work and boy does it sound good. I still have to tie up some loose ends and road test it but things are looking good.
Old May 10, 2005 | 03:09 PM
  #117
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
Are the valve covers the same for an LT1 as an L98? someone said they may be different so it got me thinking.
Old May 10, 2005 | 09:31 PM
  #118
tpi_roc's Avatar
Yes they're the same
Old May 13, 2005 | 06:02 PM
  #119
85 roc it's Avatar
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
Do you have any pics of your accessory set up. I'm doing the same thing, but the shop drilled the whole it the front of both insted of the front of the pass and back of the driver.
Old May 14, 2005 | 01:50 AM
  #120
tpi_roc's Avatar
Yea I'll take some of the pulleys and with it installed in a few days. I'm only running water/alt/PS though.
Old May 14, 2005 | 09:46 AM
  #121
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
Same here, I did find a midmount alternator bracket, probably going to run it, It was the only one that didn't mount infront of the head.
Old May 14, 2005 | 11:39 AM
  #122
tpi_roc's Avatar
my stock 85 alt bracket worked just fine.
Old May 15, 2005 | 06:14 PM
  #123
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
Good, same thing that I have, so sounds good
Old May 17, 2005 | 05:53 PM
  #124
Car: 1997 Corvette
Finally getting mine done. Found a place around here that will weld, mill, and drill/tap the coolant holes where yours are for a good price. Sending off my intake to Millican tomorrow for the distributor mods.
Old May 17, 2005 | 06:04 PM
  #125
tpi_roc's Avatar
I dont see how this is relevant?
Old May 18, 2005 | 04:16 AM
  #126
nwcc's Avatar
Engine: building a gen1 355 with LT1 heads and intake.
Transmission: Turbo 400
tpi_roc... I wanted to thank you for leading the way on this conversion. I'm sure that I am not the only person thats been motivated to take on this project after reading this tread. Again, I just wanted to thank the people who run and support this great site and I wanted to thank tpi_roc for his documentation of this conversion.
Old May 18, 2005 | 10:31 AM
  #127
tpi_roc's Avatar
I appreciate that. I also echo the comment about the greater people of thirdgen.org.
Old May 18, 2005 | 04:58 PM
  #128
bowtienick's Avatar
i have a 91 with serpentine set up. i bored through the acc bracket on the driver side. on pass side i notched it and went behind (not running a/c).
Old May 25, 2005 | 08:58 PM
  #129
ajclark7's Avatar
Transmission: 4-speed
I see you got your engine in and running. How is the engine cooling? I have mine ready to install, I'm just waiting on my tranny to arrive. Good luck, your engine looks great.
Old May 25, 2005 | 11:49 PM
  #130
tpi_roc's Avatar
Thanks for the compliments, I haven't been able to really test the coolant system yet but I should be by the weekend. I managed to blow the nose cone off my starter somehow so that slowed me down a little.
Old May 27, 2005 | 01:29 AM
  #131
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
Did you have trouble tapping the heads, my treads didn't turn out that well, the guys at Napa said that the Aluminum used was cheap
Old May 27, 2005 | 02:03 AM
  #132
tpi_roc's Avatar
It tapped very well, however like I mentioned before, drill with a press, not a hand drill.
Old May 27, 2005 | 10:21 PM
  #133
ajclark7's Avatar
what type of rocker arms did you use? I was going to order some comp pro magnum 7/16 rockers for mine, I'm not sure if they will work.
Old May 28, 2005 | 12:17 AM
  #134
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
I would use 3/8, the 7/16 may be to big for the bolts that hold down the valve cover, at least that was what I was told
Old Jun 3, 2005 | 12:02 PM
  #135
tpi_roc's Avatar
Coolant is 100% completely done, holds water, purges air, and looks nice! I'm going to clean up the engine bay and take some pictures, and road test this weekend.
Old Jun 3, 2005 | 01:56 PM
  #136
Car: 1997 Corvette
Great to hear its working so far. I have my heads assembled and I have the brass fittings for the coolant lines as well. Where are you locating the remote t-stat housing? I'm trying to decide where to put that. I'm waiting to hear word back from Millican about my intake and fuel lines and then I'll be getting my stuff installed as well.
Just out of curiosity, what were your chambers CC'd at, and what pistons are you running?
Old Jun 3, 2005 | 03:20 PM
  #137
tpi_roc's Avatar
You have a PM
The pics will illustrate everything. If anybody has a question from there feel free to ask. I'll get some up tonight or tomorrow.
Old Jun 5, 2005 | 02:28 PM
  #138
tpi_roc's Avatar
Old Jun 5, 2005 | 07:10 PM
  #139
nwcc's Avatar
Looks awesome.
I bet it runs even better than it looks.
Old Jun 7, 2005 | 12:43 AM
  #140
tpi_roc's Avatar
Click for more pics
Old Jun 7, 2005 | 10:48 AM
  #141
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Wow. That looks sweat!
It looks like alot more work than what most people were anticipating I bet.
What are you going to do about the radiator overflow tank? Just use a small one that goes up against the radiator?
So how does it work for cooling, compared to it as previously being a reverse flow cooling system? Do you expect any detonation problems, or is there someway to make this setup a true reverse flow?
Old Jun 7, 2005 | 11:18 AM
  #142
tpi_roc's Avatar
Making it a true reverse flow system is a little more tricky but people have been doing it to first generation smallblocks for a long time now. As far as the overflow bottle mine was just ugly as sin and I'm ordering a new old stock bottle to replace it.
So far at part throttle break in I dont see any detonation problems. I'm also at 11:1 compression so if it works with that, it'll happily work on an L98.
Old Jun 14, 2005 | 01:50 PM
  #143
tpi_roc's Avatar
I have been driving it daily without any issues. I mounted the power steering pump last night and will finish it tonight and finally be able to turn. Break in is a quarter way done on the clutch, soon after I can start tuning higher RPMs and get a feel for whether or not this was worth it. I'll report on performance when I've got an idea.
Old Jun 15, 2005 | 04:29 PM
  #144
bowtienick's Avatar
looking at your throttle bracket, it looks like you modified the stock one to fit the lt1 intake. is that what you did? if so, how?
Old Jun 15, 2005 | 04:46 PM
  #145
tpi_roc's Avatar
The throttle bracket is an lt1 bracket, 93 If I remember correctly.
Old Jun 22, 2005 | 10:15 AM
  #146
tpi_roc's Avatar
Final Thoughts
Everything is broken in now. I can only pull to about 4700 RPMs because I've run out of injector to fuel it. I used to pull to 6500 with my other LT1 intake on 200cc sportsman heads. After a bunch of tuning all signs point to quite a bit of power and I cant wait to quantify just how much. Its tough to keep the tires stuck to the road but when they do it pulls like a mother @#@#er. I'm very happy with the outcome, for a while there I was worried the whole project was crazy. I also get a lot of compliments on how it looks which I wasn't expecting but is a nice surprise. All in all if you have the time and resources, and you want a pretty damn custom build, (that seems to produce) I say go for it.
Old Jun 22, 2005 | 02:37 PM
  #147
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
what type of pulleys did you use, mine is almost done, engine is complete but had to get longer push rods. Plan on installing all in a couple of weeks, just need to do the intake. Plus I changing the whole car to a 90 mapo setup with a 4th gen TA dash and interior, thats going to be the fun part, I'll let you know how it all comes out.
Old Jun 22, 2005 | 03:10 PM
  #148
tpi_roc's Avatar
Stock pulleys
Old Jul 1, 2005 | 05:53 PM
  #149
nwcc's Avatar
Yesterday was judgement day for my LT1 head conversion..... I finally found the time to throw it on an engine dyno.
After a few shake down runs to get the timing and fuel curves under control. With the fuel ratio's rich and 38' total timing, It layed down 392 hp at 5500 and 446 ftlbs at 4000. Lets fast forward through several runs of tuning the timing,fuel curves, cam timing, and fuel preasure. the best run was 482 hp at 6000 and 481 ftlbs at 4300. I didn't have enough time to make a pull with nitrous. I can only guess that if I ran the 175 shot of nitrous that I should net somewhere between 625 to 650 hp
My engine combo is as follows
350 4 bolt block bored .030" over
Moroso windage tray
Crank scraper
3.48" scat forged crank (knife edged)
Eagle 5.7 con rods
Flat top JE pistons with a compression ratio alittle under 11.5 to 1
Ported LT1 heads
Ported and port matched GM LT1 intake
58mm throttle body
Custom ground solid cam:
238 int 248 exh duration at .050" .509 int .529 exh lift
272 int 282 exh adv duration 110 lobe sep.
Crane 1.6 roller rockers
Headers with 1 3/4" primaries.
Electric waterpump.
175 shot of nitrous thats progressively controlled
Last but not least, the engine is managed by Accel DFI (thats the whole reason why its heading for the dyno.
Overall I am very happy with this conversion. After my wife gets home from her photoshoot with our other laptop I should be able to scan and post the dyno printouts.
Old Jul 4, 2005 | 10:33 AM
  #150
Car: 1997 Corvette
That's simply amazing. I got my car running two days ago with the LT1 heads and intake. Today I'm going to fix a few coolant lines and drive it. I was making my own setup for the rear coolant lines (just the small vapor lines) but I've realized that is completely unnecessary on these engines as I got no air bubbles out of those lines, and it was just a smooth stream of water. I'll be buying pipe plugs today to plug those holes up.
