1/4 mile times
Old May 28, 2003 | 08:41 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
1/4 mile times
i went to the strip today to run the car before i started to work on it and here are the results
1.
reaction time:.496
60 ft: 2.400
330 ft:6.083
1/8 et:10.493
1000 et:13.695
1/4 et 16.427
1/4 MPH: 82.71
this was with car at about 230 i didnt let it sit i just hopped in staging and went
2.
reaction time:.834
60 ft: 2.273
330 ft:6.604
1/8 et:10.183
1/8 MPH 68.90
1000 et13.280
1/4 et 15.912
1/4 MPH84.26
car sat for a little while water at about 200 degrees took spare tire out.
3.
reaction time:.524
60 ft:2.478
330 ft:6.692
1/8 et:10.219
1/8 MPH :683..38
1000 et:13.283
1/4 et :15.881
1/4 MPH:87.00
air filter removed . water at 200 launched at about 1200 RPM
also my catylatic convertor is extremely bad do these times sound about right or are these horrible please comment
Old May 28, 2003 | 09:52 PM
smithtc's Avatar
Which car?
Sounds about right for the LO3 powered bird. Would expect a bit quicker times for the TPI car.
Old May 29, 2003 | 03:07 PM
Engine: LO3 and LT1
thats from the TPI car it is running like crap it wont even chrip the tires off the line at the moment its bogging really bad. i have been posting and everything i seem to try doesnt work. i found a recall on the coil and module but they said the recall ended 8 years ago
Old May 29, 2003 | 04:20 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Sounds like it is in need a good tune up. If that is the stock coil and module I would recommend replacing them. Are you running on street tire or drags? What kind of times were you expecting and what kind of times do you want?
Old May 29, 2003 | 10:14 PM
Engine: LO3 and LT1
i was running on street tires but i wasnt spinning them the tires barely chirped. i am probbably changin the coil n stuff on sat morning. i was hoping on a 15.6 atleast with the stock car. i hope to get it into mid 14s by the end of summer which shouldnt be to hard if i can figure out the idle and bogging problem
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
