single plane fuel injection????
Old May 28, 2003 | 11:02 PM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
single plane fuel injection i heard a guy talk about it today and i was wondeirng what is that does it make more power he was saying that is like working with a carb but its fuel injected. i have the superram would that do better than the superram? any info would be appreciated thanks very much
Old May 29, 2003 | 01:01 AM
airdeano's Avatar
like the carburetor intakes they are rated at what rpm the power
needs to be at.
so if you converted a victor junior intake (3000-8000rpm) then you
are looking for power between 3000-8000rpm.
more power when is what your looking for...
airdeano
Old May 29, 2003 | 02:42 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Since it's not flowing fuel through the runners it has a little more airflow capability than it's rated at for a carb'd application.
A 4bbl. style intake is a perfectly valid solution if you want to do something different than the TPI intakes.
SuperRam vs. a 4bbl intake? Depends on which 4bbl, intake and what rpm range you need your power in.
Old May 29, 2003 | 07:38 AM
daxfas26's Avatar
Engine: 385 stroker
cool thanks for the response. so its like having the benefits of a carburator but with fuel injectors? i just had a new setup built suppose to fire the car up today for the first time in 9 months. im hoping to see 11s in the quarter without the use of nos. we ll see... could this intake set up help me get where i want to go? another question i read on another thread what is the slp t-ram intake??? thanks again!
Old May 29, 2003 | 09:28 AM
jmd's Avatar
jmd
There are no benefits to a carburetor.
Search this board for T-Ram. You'll find info.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
Jake_92RS
Aug 11, 2015 10:39 AM
