Which sensors to use?
Old Jun 3, 2003 | 06:00 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
Hi,
I'm putting a 327 engine in my 92 RS and I'm using fuel injection, Speed Density( will be Miniram soon). I bought a complete TPI setup off of a 91 GTA. The TPI has 19# injectors, so the sensors are for a 305. I want to know, besides changing for larger injectors, can I use the 305 sensors for my 327 retrofit or should I use 350 sensors?
Old Jun 3, 2003 | 06:46 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Most of the sensors are the same...
Old Jun 3, 2003 | 10:07 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
The only sensor that will be different is going to be the knock sensor. I think that it should work fine with the 327, but if you are going to be running headers and stuff like that, you might want to grab a 350 knock sensor.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
