Dyno Results
Old Jun 13, 2003 | 02:51 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Dyno Results
Went to the dyno the other day and the results are not great but not too bad considering that the engine still has the peanut cam and unmodified heads and base which together are robbing the engine a lot of potential. But the good thing is that this will serve as a baseline for future mods(mods list in sig link). The runs were done on 3rd gear so it starts at a pretty high RPM already.
The results were: 184 RWHP / 280 RWTQ
Here is the dyno sheet:
http://home.earthlink.net/~ozvresto/GTA/dyno1sm.jpg
I had previously done some datalogging using WinALDL and it was showing the Fuel/Air Ratio to be way too rich. So the fuel pressure is coming down. At the time I was also running 10deg base timing but it was showing some knocking around 3200 RPM, so I had to set it back to 8deg which is were it ran in the dyno.
Next on the agenda is to get that cam changed and the heads worked on. The cam I am considering is the CompuCam 2030 (adv. 260/270, @.05 204/214, lift 429/452, LSA 116). I know this is just a 305 but I don't have money trees in my backyard, it will have to do until I get a 350 block and bolt everything to it.
We'll see what happens.
-Ozzy
Old Jun 13, 2003 | 02:59 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I wouldnt even bother with the cam you listed. Thats basically a stock L98 cam. If your on a budget, look into the LT1-LT4 cam or a zz4 cam. They can be had usually for around $100-150.
Old Jun 13, 2003 | 05:02 PM
age's Avatar
age
Car: 1992 Z28 1LE
I agree... I think you should definately think about the ZZ4/LT4 HOT cam. Maybe get some 1.6 rockers.. do some work on the intake/heads. You'll be good to go..
Old Jun 13, 2003 | 05:55 PM
smithtc's Avatar
Hey Ozzy...
You might remember me. I had the Red GTA at the Trans Am show a year back. Anyway...I have an extra L98 cam, and a pair of 305 heads with perimeter bolts, or maybe even an extra pair of L98 iron heads if your interested...cheap of course.
I do have a brand new LT4 Hot Cam and corresponding timing chain that I might not use if your interested.
Just PM me if your interested.
BTW...those are some good numbers I think for a 305 to the rear wheels, especially for a peanut cam
Old Jun 13, 2003 | 10:11 PM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
I do have 1.6 rollers already and if I get a cam like the zz4, it will put the lift at 506/544? With the LT4 HotCam it is 560/560. I think that might be too much, or maybe not I am no expert at this. What ever I do I am planning on a custom PROM too.
Hey, long time no hear from you. I've been gone for a while, just hanging around the GTA Source Page, not much going on there anymore. I did some pricing at a Pensacola shop on some head work and I can get them done for about $300. That is with 1.94" intake valves, 3-angle, tapping for screw-in studs, and doing the deck. So I am going to re-use my heads. Thanks for the offer.
Now what about a cam that will work with 1.6 rockers without going too big on lift.
-Ozzy
Old Jun 17, 2003 | 01:46 PM
smithtc's Avatar
The LT4 hot cam I have (which is brand new) comes out to .525/.525 with the 1.6 rockers...I may decide to use it anyway, even though it likes stealth ram or miniram type induction.
If you want to go cheap and use L98 cam I can trade you for some prom help...lifts would come to .442/.459 with the 1.6 rockers...
I think your zz4 cam lifts may be off as well, but I can't say off hand what they should be. Most like the ZZ4 cam with a TPI set up.
Ozzy, I just thought you might like to use a spare set of heads...lots of them around at local yards for cheap ($20-$30)
Where did you get your car Dynoed at...P'Cola or Crestview?
Old Jun 21, 2003 | 03:56 PM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
Sorry for the delay in responding. To calculate the lift when using the 1.6 rockers I used the following formula:
New lift = Lift / 1.5 X 1.6
I got the car dynoed at Adams in Crestview.
As far as the heads I might just do that, buy a set and practice on before doing mine. Thanks,
-Ozzy
Old Jun 22, 2003 | 07:00 AM
e-man's Avatar
Car: 89 formula
Engine: 383
The hot cam lift with 1.5 rockers is .492 W/1.6 rockers its .525
Old Jun 23, 2003 | 07:30 PM
iroc_cragg's Avatar
What are all ur mods and what kinda dyno did u use.
Mustang Dynometer or a Dyno Jet. The Mustang Dynometer has 2 rollers, and the Dyno Jet has one big drum roller.
Old Jun 24, 2003 | 08:42 PM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
It was a Dynojet (info in dyno sheet).
Mods:
INDUCTION
K&N Air Filter, Modified Air Box, Modified MAF, Jet Throttle Body Airfoil, Ported Plenum
COOLING:
Modine Radiator, Flow-Kooler Water Pump, 160° Thermostat, Hypertech Fan Switch
PROM:
Hypertech Termo-Master
IGNITION:
MSD 6A, MSD GM Blaster Coil, Holley Annihilator 9mm Cables, Splitfire Spark Plugs
LUBRICATION:
Mobil 1 Synthetic Oil
EXHAUST:
Edelbrock TES Headers w/3" Collector, Catco Catalytic Converter(3" in/out), Flowmaster 3" Catback w/American Thunder 80 Series Cross-Flow Muffler
FUEL SYSTEM:
Crane Adjustable Fuel Pressure Regulator
ENGINE/MISC.:
March Underdrive Pulleys (crank, water pump, alternator), Cloyes True Dual Roller Timing Chain, Scorpion 1.6 Roller Rockers
TRANSMISSION:
Newly Rebuilt 4L60, TransGo Shift Kit, New Valve Body, Throttle Valve (higher than OEM downshifts), Corvette Servo, 2500 Stall Converter
TIRES:
Bridgerstone Potenza P245/50ZR-16
Old Jun 24, 2003 | 10:44 PM
iroc_cragg's Avatar
ur puttin out some good numbers. alot of torque for a 305.
Old Jun 24, 2003 | 10:53 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
get rid of that peanut cam, i bought a stock grind lt1 cam for 20 bucks, gained 3mph with it at the track and thats swapping from a l98 cam.
Old Jun 25, 2003 | 04:51 PM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
Originally posted by SLP IROC-Z
get rid of that peanut cam...
That's the plan, I am already looking and comparing.
Originally posted by iroc_cragg
...alot of torque for a 305.
Yeah, unfortunately is not over a wide range. It drops quickly like a rock. That's that stupid peanut cam.
Old Jun 25, 2003 | 07:56 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Just to correct you, ZZ4 is not the same as the LT4 Hot cam. The ZZ4 has a duration of 208/221 at .050". and the LT4 has a 218/228. Totally different.
Old Jun 25, 2003 | 08:33 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Another thing, It was 90+ when you got tested. I look forward to seeing the change when you get a new cam.
Brian
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
