programable LS1 to TPI MAF converter
Old Jun 28, 2003 | 06:52 PM
funstick's Avatar
im running an intrest check on something like this. the later model LS1 mafs flow about double what the factory TPI units can. This will have a completely PC tuneable curve. i will also make avaiable for all the diy prom guys code to DIY the tunning them selves and for those who simply want to just do a swap in ill make a very affordable chip avaiable simply to take advanatge of the biger maf.
in thoery you can rework the maf for bigger injectors etc via the converter but you run the risk of mesing with timming. still to reduce the restriction and be able to touch up and fine tune the maf curve is a niceity in it self.
ill be looking to put these out in the range of $250-275 each. if there enough interest ill run a group buy. MODS please do not lock this. this is Just and interest check nothing for sale. question comment.??
this will also adapt any 0-5volt maf from any company. as stated no ***** no bottons youll plug in the pc and tune the curve.
in thoery you could run a 95mm lightning maf sensor on your tpi or a ls1 etc etc etc.
Old Jun 28, 2003 | 10:44 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There are a couple guys here running 10s with MAF cars using the stock MAF. As long as you can achieve the proper a/f ratio with tuning, the MAF doesn't pose the major restriction that some people seem to think it does.
Old Jul 1, 2003 | 06:09 PM
funstick's Avatar
yeah but going to a maf that can read air at those volumes and reduce restriction certianl could help.
69 Six Pack
Oct 5, 2015 07:51 PM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
