Smoke and Smell on TPI
Old Jun 29, 2003 | 09:12 PM
YellowDmon's Avatar
Ok, on startup it blows out a big cloud of smoke. I think it is blueish indicating oil leak. Well when I was driving on the interstate today at about 75-80 mph and let off the gas I could smell something. I thought it was the smell of oil but it could have been coolant. I am not exactly sure. When I let off the gas the oil pressure gauge fluctuates too. Any ideas?
Old Jun 29, 2003 | 09:15 PM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
sounds like time for a rebuild
Old Jun 29, 2003 | 09:46 PM
YellowDmon's Avatar
That is what I was afraid of, but it just gives me more of a reason to go with the Vortec stuff.
Old Jun 30, 2003 | 08:03 AM
bigals87z28's Avatar
Car: Check The Sig
the vortec stuff will cost you more in the long run, as you will have to get a brand new intake base to fit the bolt pattern. And the 305 vortecs have a bigger combustion chamber you will lose power. Also i heard the vortecs are good, but not that good especaily on a 305. If its a little, it could be your valve seals, but it sounds like you might have some blow by... looks like its time for a 350!! or greater!!!
chazman
Aug 28, 2018 03:25 PM
dyeager535
Aug 28, 2015 08:10 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
chazman
Aug 22, 2015 02:01 PM
Sanjay
Aug 12, 2015 03:41 PM
