AFPR or Fuel Pump?
Old Jul 1, 2003 | 08:57 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
AFPR or Fuel Pump?
I am using a fuel pressure guage taped to the windshield and no matter what I adjust the AFPR to, it drops to about 38lbs at WOT. I even adjusted the pressure to 60lbs with the vacuum line off and again when i ran it, back to 38lbs. I did notice at that pressure, the needle jumps constantly about 10lbs. On one of the runs I left the vacuum line off the entire time to determine if vacuum was a factor, same results.
My question is whether or not it is my AFPR or Fuel Pump? Something else all together?
Any advice is appreciated.
Old Jul 1, 2003 | 10:41 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I'm really not sure what the problem is but I can tell you that if you run the fuel pressure at 60 for too long then the fuel pump will become a problem. Sixty is waaayyy to high IMO.
Old Jul 2, 2003 | 05:47 AM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Axle/Gears: 370 BW
I know that! It was a test to see if there was any way to increase the pressure at WOT. Can someone assist with providing me an answer to my questions? I would like to replace the trouble maker today.
I've done the fuel pump job on a buddies car and not looking foward to doing it again. Especially if I complete the job and still have the problem with fuel pressure.
Thanks.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
