car unloads under pressure
Old Jul 5, 2003 | 10:14 PM
firebirdconv92's Avatar
Car: 2001 Silverado (I miss my 3rd gens)
Engine: 4.8
hey everyone, thanks for checking this forum out. My '86 305 TPI is bogging down when you step on the gas. It may be old plugs but the lady I bought it from says it had a complete tune-up last fall. ?
Any help will help.
Old Jul 6, 2003 | 09:26 PM
smiley23's Avatar
Had the same problem - start by checking the ignition module - fuel filter - or the coil.
https://www.thirdgen.org/techbb2/sho...hreadid=187418
Old Jul 6, 2003 | 11:15 PM
airdeano's Avatar
Re: car unloads under pressure
doesnt mean that they changed the plugs, or did anything.
pull a plug, look at it, check the center electrode, is it rounded over?
are the correct plug for your application?
check the inital timing (bypass disconnected) 4-6° BTDC?
fuel pressure, timing, ill TPS can cause hesitation, bogs and lack
of performance.
airdeano
specialized
Jun 18, 2022 09:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
Kaweh
Aug 9, 2015 02:54 PM
gwade12
Aug 8, 2015 08:17 AM
